Counter/Timer
USB 6211 with 2 Encoders labVIEW Interface
I am trying to use 2 encoders (780251-01) to measure shaft rotation of 2 shafts to assure that they are rotating at the same velocity.  The encoders I plan on using are 780251-01 with a NI USB 6211.  I am seeking assistance on creating a VI.  Any help would be appreciated as I am a beginner to LabVIEW.  In the futiure, I plan to implement a National Instruments load cell. ( 783212-01)
(5,584 Views)
We have a great getting started guide for setting up encoders. The following guide will walk you through creating a DAQmx virtual channel for your encoders:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
If you need help implementing the virtual channel into your LabVIEW code, we have a tutorial for that as well:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0VbCAI&l=en-US
Daniel C.
(5,564 Views)
