Counter/Timer
USE OF Type cast function ?
can any one explain the use of type cast function with help of example please i am not able to understand the explaination given in ni.com site
(7,594 Views)
LabVIEW provides a function called Type Cast, which allows data to pass through it unchanged while the type of the wire changes. Please refer to the given link which elaborates on the type cast function with required instances.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/type-cast.html
In case of any clarifications needed, do revert.
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(7,473 Views)
Type cast pretty much does what Sahil indicated, it changes the data type without changing the data (to the best of its abilities). Converting between data in different structures and of different sizes can result in strange behavior but the concept is still the same. Was there a specific question about how it works?
Austin
Staff Software Engineer
NI
(4,829 Views)
I think this shed more light on this special function. Similarly recently I saw a really rare example. A Hello World obtained in a strange way, using the Type Cast function.
(4,791 Views)
