Counter/Timer
Using LS7083 for quadrature encoders
I just read Application Note 084 from 7/9/1999 that recommends using an LS7083 quadrature clock converter to eliminate miscounts due to vibration at low speed on an E Series board. It makes sense from what I have read, question is: does this apply to the M Series board I am using as well - PCI6220?
Ed
(3,639 Views)
Ed,
True quadrature conversion is a built-in feature of the M-series boards so there should be no need for an LS7083 or similar interface circuit.
Personal testimonial: I've been using an M-series counter connected directly to a quadrature device for several months with no miscount issues. The device is a non-contact laser interferometer that resolves at the sub-micron level, and we're getting very repeatable measurements. This in an environment where the otherwise unnoticeable air currents from normal operation of the HVAC system cause a vibration-like fluctuation in counts.
-Kevin P.
(3,629 Views)
