Counter/Timer
Using NI 9205 or NI 9403 DIO module for encoder measurement
Is it possible to measure angular position by counting pulses from a quadrature encoder using NI DIO 9403 or NI 9205 modules coupled with cDAQ 9174. I do not have access to other modules which have inbuilt counters. If possible, can someone please guide me on how to do that?
(2,355 Views)
What resolution do you need?
What device are you using?
I suggest you search for a "Quadrature Decoder Circuit" and couple that up to a suitable up/down counter with reset. An example is the 74HCT193; cascade as many of these 4 bit blocks as you need to get the number of bits you require. You can reset on the z input, from some limit switches or from a digital output from your 9403. The parallel lines from your counter go into digital inputs on the 9403.
Oh look someone has done it all for you here: http://mumris.eu/Decoder.htm .
(2,298 Views)
Thank you so much @SteveD123.
I have tried counting the pulses using LabView but there was a huge lag. So, I have coupled with an Arduino and used interrupt program to count the pulses. Later, I have coupled it with a serial input program to access the counter value.
It worked fine for me.
(2,287 Views)
