Counter/Timer
Using NI 9411 module and Futek TRS 605 for Rotary Encoder Measurements
I am currently using an Futek 605 torque sensor to measure torque and RPM. The torque measurements can be collected fine but unfortunately, I cannot read the pulses generated from the rotary encoder for RPM measurements. I have wired the device to the DAQ system according to the counter terminal guide in the manual; using the edge counting function with settings counter terminal 1: Angle A is wired to PFI 3 and Angle B is wired to PFI 5.  Any help on troubleshooting this problem would be greatly appreciated.
DAQ: NI-cDAQ-9174
Module: NI-9411
Torque Sensor/Rotary encoder: Futek TRS 605
Message 1 of 1
(1,355 Views)
