Counter/Timer
Using the 6525 counter to measure frequency: is there a neater way?
I'm currently using the high speed counter on the a USB 6525 module to measure the frequency of a spinning object via a hall effect sensor.
I was wondering if there was a simpler/ more effective way of coding it than this?
Currently all I do is take the current counter reading, wait a second, take another reading and subtract one from the other. The result is the frequency, in hertz.
Is there a way of getting the 6525 to return the count/ change in count after 1 second?
(6,676 Views)
The counter can measure the frequency directly.  Just create a counter frequency task.
(6,663 Views)
Thanks for commenting. I'm not sure if I'm doing it right though or whether the NI USB 6525 can't handle this type of measurement?
I keep on getting an error that says to effect it can't do this type of operation.
Can you advise?
(6,647 Views)
Accepted by topic author AndyF
On the 6525, you only have an event country and you cannot do a frequency measurement.
(6,614 Views)
That's what I suspected after trying, thanks for confirming.
(6,599 Views)
