Counter/Timer
View RTSI State
I would like to view the state of the RTSI lines while my program executes to help with debugging.
Does anyone have a VI that allows me to read the rtsi lines with the 6602 or 7344 card? If not can you suggest an approach to writing my own, perhaps using route signal and then read the PFI line.
(6,282 Views)
Hi Frank HS,
I haven't found any such VI searching internally. If you wanted to route a signal from the PFI pin to a RTSi connector you would have to use a DAQmx VI. The function is called DAQmx Connect Terminals and you can connect a PFI line to the RTSI line. The PFI line again is on the pin out diagram that you can access from Measurement and Automation Explorer. Just go into MAX and right click on the device and select device pin out to find where the PFI line is.
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(6,274 Views)
