Counter/Timer
Visa.h under NI-DQmx 8.7.1
I have an measurement program (C#) which works under Win2000 and NI-DAQmx 7.4 perfect using a trigger.dll written in C++. But under WinXP and NI-DAQmx 8.7.1, it always crashes without any announcement by importing the .dll. ([DllImport("trigger.dll")])
After looking to the source code, I think it's because there's no visa.h any longer in 8.7.1. Have I to rewrite the trigger.dll (in C#) or it's known an another solution?
(3,861 Views)
Hi Herby,
if you are using the visa function in your trigger.dll you have to install the NI-VISA driver.
Hope this helped out and feel free to reply if you have more questions
Best regards
Benjamin
(3,823 Views)
It is installed.
Also I found the reason why the trigger crashed. In the "VISA Interactive Control" the 6602 is not indicated. Thus, the trigger does not found any card. So i had to write the card directy in the trigger and not searched and choosen by it.
But why it is not indicated, I do not know. Probably an error installing the driver or something like this.
Thanks for answer.
Hannes
(3,819 Views)
