Counter/Timer
What is error 50103? at DAQmx START task?
HI Thomas,
Thanks for the link.  I had already read that article, and it is for Labview 7.0, and I am running 2012.  The article calls out some things that are not in LV2013, so, it is somewhat obsolete.  It is also quite general, and could be written in higher level detail to be much more useful.  Thanks for the offering, though.
Dave
Message 11 of 14
(3,171 Views)
OK, I got rid of the error 50103 by adding the Counter Input Terminal to the property node.  Thanks.  Solved!
Message 12 of 14
(3,167 Views)
hey i am using proximity sensor with connection to 14,16 and 1 pins of NI 9401.From test panel i checked sensor getting supply but when i run my labview program sensors light turns off and unnamed task error coming.Please help me.
Message 13 of 14
(3,060 Views)
Hello Mass0873,
I would strongly suggest creating a new forum post with your issue instead of posting on one from months ago. This will give you better visibility and will also allow the forum to better understand your specific issue since it isn't really related to the current thread.
Jonathan L.
Technical Support Section Manager
Message 14 of 14
(3,052 Views)
