Counter/Timer
What is the default gate frequency for the PCI-6602 DAQ?
What is the default gate frequency and default source frequency of the PCI-6602 DAQ?
(3,385 Views)
Hi coachcalamai,
The default behavior on the gate is as if there was no signal on the gate (ungated). If you want a trigger or to send a signal, you will specifically have to set it.
The default signal on the source is the 20MHz internal reference.
Anyway, hope that helps. Have a good day.
Ron
(3,385 Views)
