Counter/Timer
What is the pinout for the 6602 relative to the 'D' connector.
I am developing a custom board to connect with the PCI-6602 Counter/Timer card.  I will use the SH68-68-D1 Shielded Cable, 68-pins, 2 m to connect from the 6602 to the custom board.  What I need to know is what is the pinout relative to the 'D' connector.  The manual shows the connector as a rectangle.
Tony
(3,829 Views)
If you have the actual hardware, pin numbers are typically stamped into the connectors.
(3,821 Views)
Thanks for the idea.
Normally yes, but the original designer does not always follow the manufacturers spec, in this case, the manufacturer labels them A1-A34 and B1-B34.  Additionally, if I had the card, I could figure it out, but unfortunately, I do not have it yet.  Thanks.
(3,818 Views)
Hi Tony,
The routing from the PCI-6602 through the SH68-68-D1 is one-to-one, so I believe that all you should need is the pinout for the 6602.  This is shown below.
This information can be found in Measurement & Automation Explorer (MAX) by right-clicking on the device and selecting "Device Pinouts".
I hope this is what you needed.  Post back if you have further questions.
Ed W.
Message Edited by Ed W on 12-13-2006 04:14 PM
(3,802 Views)
