Counter/Timer
What is the "time limit" in the function pulse-period?
J'd like to have a more precise definition about "time limit" :we find it in the function "pulse-period".Please ,J'd like to know why this program doesn't function.
(3,665 Views)
Hello;
The Pulse Period.vi is measuring the time the input pulse is high or low, and the time limit is the period to wait for a valid measurement, which means, you can set up a time out if a valid pulse didn't come to the counter gate pin. If time limit is -1.0 (default), the time limit is set to five seconds or four times the range of the counter at the selected timebase (4*65,536/timebase) in seconds for the Am9513 and (4*16,777,216/timebase) for the DAQ-STC), whichever is larger. You can input customized values at this parameter as you wish.
Hope this helps.
Filipe
(3,665 Views)
Your answer has helped me very much.Thanks.
I'd like you to have a look to the program joined to the question.
(3,665 Views)
