Counter/Timer
Why no PXI-6624 pinout names in text or spreadsheet, or most other NI boards for that matter
Why are there no cut/pastable PXI-6624 pinout names in text or spreadsheet, or most other NI boards for that matter.
National should have a section with spreadsheet for each and all board pinouts, or at least pdfs with actual text (vs an image) of the connector
***Customers dont want to have to type in manually hundreds of pins names and risk typos leading to board design errors.
It's not a laziness factor, it's a risk mitigation issue.
Xilinx learned that this makes customers more likely to use their products in the design phase.
Thanks for listening,
Lee Studley
(5,844 Views)
Hello Lee Studley,
If you click on this link you will be directed to the product page of the PXI-6624. Under the Documentation is the Manual for the NI PXI-6624. If you click on the link for the manual you will be directed to information such as the user’s manual, specifications and other documents that typically ship with the device. In the User’s Manual PDF on page 3-8 or on the last page of the Specifications pdf is an image of the Device Pinouts. You can copy the Pinout names from these PDFs to a text document or excel. The directions above are applicable to most of our devices.
Izzy O.
(5,832 Views)
