Counter/Timer
alcohol gas sensor MQ3
I am doing a project in which I want to build a breathalyzer.  I got a MQ3 alcohol sensor, but am having problems setting up the DAQ assistant to get the correct readouts.  I'm stuck....does anyone know what I should try next???
Thanks for your help in advance!!!
(6,330 Views)
Duplicate post, see here:
http://forums.ni.com/t5/Counter-Timer/alcohol-gas-sensor-MQ3/m-p/1547692/highlight/false
-AK2DM
(6,328 Views)
Thanks for the help...If you want a little more information on this, I have posted it in the "new discussions" area under URGENT!!!! easy projects that use transducers.  Also there is no code, everything needs to be done with LabVIEW.
Thanks again!!!!
(6,317 Views)
