Counter/Timer
alcohol gas sensor MQ3
I am doing a project in which I want to build a breathalyzer.  I got a MQ3 alcohol sensor, but am having problems setting up the DAQ assistant to get the correct readouts.  I'm stuck....does anyone know what I should try next???
Thanks for your help in advance!!!
(6,481 Views)
Must resist, but can't- did you drink the prescribed number of beers in the manual to calibrate your scaling factor 🙂
Seriously, can you post documentation on the MQ3 and how you have it wired to your DAQ card, and what DAQ card are you using. Also post your code too.
-AK2DM
(6,480 Views)
