Counter/Timer
angular position measurement
how to used encoders to angular position measurement of rotating shafts
(5,970 Views)
this is my program
(5,967 Views)
Hi Sabry,
what is your question? Good starting point is to open LabVIEW Example Finder and check code examples located in Hardware Input and output » DAQmx » Counter Input section. You can also try to search at NI Developer Community web. This table shows Default NI-DAQmx Counter Terminals on your C-Series module NI 9401 - http://zone.ni.com/reference/en-XX/help/370466W-01/device_pinouts/9401cdaqpinout/
I also recommend you to read this White Paper which can give you good outlook on Encoder Measurements.
Regads,
Ondřej K.
NIEE AE
CLA, CTA, CLED
(5,932 Views)
