Counter/Timer
automatically stop a vi execution when condition is met
I am looking for a very simple method to stop a VI execution when the preset condition is met (ex:  I use a "for" loop in a "Formula Node" to read the number from an arrary, I compare the data with a constant each time the data is read, then I want to VI execution to stop when the condition is true.
Thanks.
(8,966 Views)
Hi Iywillc!
Please take a look to the code I've attached. It includes a for loop with a stop condition. This can be created by right clicking on the loop and activating the conditional terminal.
I hope this helps!
Kind Regards
Carlos O
(8,960 Views)
This is not exactly what I was lookng for.  I use a"Formula Node" in my appication.  A small C program (for loop to read a 1-D array) is written to compare the data in the array.  If the condition is met then the execution will stop.
Thanks.
(8,958 Views)
Update of my VI model.
(8,956 Views)
I think I got it work.
(8,954 Views)
     Iam using LV2009.So I can't view this example.Can anybody please convert it for me?
     Thanks.
Thanks as kudos only:)
(8,892 Views)
Hi!
There you go! The attached file is saved for LabVIEW 2009.
Mikhail
RF Toolkits, Product Support Engineer
(8,882 Views)
