Counter/Timer
buffered position measurement
Hi I'm using a NI6602 to perform buffered measurements of a position encoder triggered by an external clock signal (I generate it with another counter).
The code is at the end.
I'm using /dev1/ctr4 for the position task and /Dev1/ctr6InternalOutput (that I'm generating elsewhere) to trigger the buffered acquisition.
My problem is that when I run the code I get the error below, as if it was pretending to use the internal timebase instead of the A signal of the encoder (the A signal coming through the RTSI1 that I already connected to the Ctr4Source before)
Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
Source Device: Dev1
Source Terminal: 80MHzTimebase
Destination Device: Dev1
Destination Terminal: Ctr4Source
Required Resources in Use by
Source Device: Dev1
Source Terminal: RTSI1
Task Name: posTask
Status Code: -89137
Can anyone explain me why is it trying to use the 80MHz signal and put it in the source?
Thank you very much in advance.
Here is the code snippet:
posTask = TaskHandle()
positionZidxEnable = bool32(0)
positionZidxVal = float64(0.0)
positionPulsesPerDist = float64(1.0)
positionInitialPos = float64(0.0)
sampling_freq = 1000
positionSamplingRate = float64(sampling_freq)
positionSampsPerChanToAcquire = uInt64(detectorTaskPulses)
positionSampsPerChanToRead = int32(10)
positionSampsPerChanRead = int32()
positionReadTimeout = float64(1)
self.DAQmxErrChk(nidaqmx.DAQmxCreateTask("posTask",byref(posTask)))
self.DAQmxErrChk(nidaqmx.DAQmxCreateCILinEncoderChan(posTask, '/dev1/ctr4', "PositionChannel", DAQmx_Val_X4, positionZidxEnable, positionZidxVal, DAQmx_Val_AHighBHigh, DAQmx_Val_Ticks, positionPulsesPerDist, positionInitialPos, None))
self.DAQmxErrChk(nidaqmx.DAQmxCfgSampClkTiming(posTask, "/Dev1/ctr6InternalOutput", positionSamplingRate, DAQmx_Val_Rising, DAQmx_Val_ContSamps, self.positionSampsPerChanToAcquire))
Message 1 of 1
(5,753 Views)
