Counter/Timer
cRIO: FPGA loop running at twice the onboard clock speed
I have a pulse counting application using the NI cRIO 9053, which currently uses the onboard clock for timing (40 MHz):
This works basically fine, but I am missing 80% of the pulses because they are coming in at a too high rate. (pulse width is ~10 ns)
I thought about using a faster loop speed, by creating a "derived clock" at 80MHz:
I've been modifying the FPGA VI accordingly:
but that doesn't work at all.
I guess I have been a bit too naive here and I am now assuming that I will need a (much more expensive) PXI system if I want to catch all the pulses.
I would be grateful for any advice or confirmation of my suspects.
Best,
Alex
Message 1 of 1
(1,098 Views)
