Counter/Timer
changing timebase for buffered counting
I am preforming a buffered period measurement of a TTL pulse with a 6602.  Currently I am using the default internal 80 MHz clock as the counter source.  I want to view the periods as ticks.  Is it possible to change the timebase to the 20 MHz or 100 kHz internal clock?
Also I am using Matlab and DAQmx to write the code.
(3,985 Views)
I figured it out.  Using DAGmxSetCICtrTimbaseRate gets teh job done.
(3,977 Views)
