Counter/Timer
count edges on rtsi0
Hi all,
I have a PCI 7831-R and a PCI 6143 card running on my computer. Both are synchronized with a RTSi cable. The PCI7831 delivers via RTSI 0 a clock signal for Trigger my analog signals. My problem is now that i want count the edges on rtsi0 because I want to know what  the values  of my analog signal are refered to my triggersignal. For example, Trigger edge 1 - analog value x,  trigger  edge  2 - analog value x. Is that possible. I don't found nothing on ni examples. Thank you for your help.
Grüße aus Deutschland
Manuel
(3,459 Views)
Manuel,
you want to count edges from a RTSI line with the PCI 6143, right?
Have a look on the following post:
http://forums.ni.com/ni/board/message?board.id=250&message.id=4715&requireLogin=False
ThSa
Message Edited by ThSa on 04-05-2006 09:42 AM
(3,455 Views)
