I have a PCI6602 card which I want to use to measure instantaneous angular speed from 3 different sensors (a quadrature encoder, magnetic pickup+gear and optical sensor – with conditioning to give a TTL output). I think this means I need to connect each of the signals to the GATE on three of the counter channels, with the sources set as the internal time base, so that I can do continuous period measurements on all three channels.
My question is, is it possible to configure the counter to start timing simultaneously on all three channels upon receiving a reference signal, such as the “Z” signal from the encoder? If so, how do I do this and where should the reference signal be connected to?
Also, I have been trying to write a program in LABVIEW to acquire period measurements on three channels, but the DAQ assistant won’t let me have more than one channel in the task (when I run it, it says I need the multi channel version of DAQmx read but I cant find this). I could have 3 separate tasks to acquire each channel but I’m not sure if they would be synchronised if I did it that way? (I tried it with the execution highlight thingy on and it seemed to do one measurement after the other).
Thanks, 🐵
Tim
