Counter/Timer
counting ttl pulses with pci6014 and traditional DAQ
My goal is to count ttl pulses over a specified bin size from an APD photon counter.
I dowlnoaded Count_Events-Easy (DAQ-STC).vi from the NI website, and tried using it to count ttl pulses through the PFI 0 channel of my pci-6014 basic multifunction DAQ.  If I run the vi continuously it does not display an counts unless the Measurement & Automation test panel is open for the pci-6014 and I select the corresponding counter and event source under Counter I/O.  The vi counts match the  test panel counts, for what that's worth.  If I reset the counter I/O test panel the vi stops counting and will not start again until the counter I/O is restarted.  Also, if I stop the vi  the test panel also resets.
Why won't the vi run on its own?  Is there something obvious I'm missing here?
(3,249 Views)
Ian,
Please see the answer given in the following post:
http://forums.ni.com/ni/board/message?board.id=170&message.id=130996
Good Luck!
Ryan V.
Message Edited by Ryan V on 07-13-2005 03:16 PM
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,237 Views)
