Counter/Timer
delayed pulse
I want to generate a pulse triggered by a counter. The counter part works well (see code attached). However,
the pulse generated either won't work or will work for about 1 second, depending on one line commented or not.
I checked that the wires were connected correctly and that ctr2 works properly with MAX.
Any ideas?
(3,845 Views)
Found the problem.
Some code elsewhere was interfering with the code and killed the task.
(3,843 Views)
