Counter/Timer
device identifier is invalid
I am a complete newbie and am trying to use my brand new PCI-6601.  Measurement & Automation Explorer reports the name of the board as "Dev1" and the test panel application that uses "Dev1/ctr0" works properly.  However, when I compile and run the cntDigEvents.c example program provided with NIDAQmx, I get an error message "DAQmxBase Error: <err>Device identifier is invalid".  The device name ("chan[]") used in the example program is Dev1/ctr0 which seems to me to be correct.
Any help would be greatly appreciated!
(5,909 Views)
In the immortal words of Rosanne Rosannadanna, never mind....
I didn't understand the difference between MAX and MAXbase.  Presumably there is a high level roadmap to this stuff somewhere, but I haven't found it yet.
(5,897 Views)
marc,
DAQmx Base is our platform-independent driver which can be used on Windows, Linux, Mac, and PDA. If you will be developling solely for Windows, I would recommend using NI-DAQmx (no Base) as it exposes more of the functionality of your device.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(5,885 Views)
Like all things on this web site no useful information was provided.  SO why have NI-DAQmxBase if you can't do what you need with it.  I'm having the same problem in 2010.  I guess I'll try to install NI-DAQmx because that's more useful.  I just need to read a few AINs and DIN I can't believe the trouble I've had with this s/w.  Even their examples don't work, sad.
(4,705 Views)
