Counter/Timer
difference in frequency mesure between use of one counter and multiple counter
hello, i would like to mesure frequency with NI PCI 6624 in different points, so i have found some examples where it is used in such of them one counter and in other it is used 2 counter to one mesure , i would like to distinguish the difference or the interest to use multiple counter for one mesure , tanks
(5,779 Views)
The reason to use different methods is to increase the accuracy for high frequency signals or for signals with a large range at the expense of using another counter.
This tutorial on ni.com explains how these different methods work:
http://zone.ni.com/devzone/cda/tut/p/id/7111
Let me know how you get on with this and if I can be any more help.
Nick
(5,775 Views)
