Counter/Timer
digital waveform on rtsi
I have programmed a digtal waveform which I can send out via a Multifunction Card. This waveform is clocked by the clock on the card. Is it possible to get this waveform on an RTSI line? I can't find any exmples...
Tim
(3,651 Views)
Sorry, but there is no way to route a digital output to RTSI.
Jochen Klier
National Instruments Germany
(3,636 Views)
Thanks for the answer,
I have found a solution:
I gave the digital output to the PFI0 port of my PXI5404 signal generator card and routed it from there with the NI Fgen route signal out.vi to the rtsi0-line.
Thanks anyway
Tim
(3,634 Views)
Ok, this will work with the 5404 but in your initial posting you wrote that you are using a multifunction DAQ board and this solution will not work for this type of board.
Jochen
(3,633 Views)
