first of all it would be helpful to know what NI hardware you would like to use the code with.
I found a forum post that discusses a similar issue:
http://forums.ni.com/ni/board/message?board.id=40&message.id=1536Basically you need to create one counter channel (e.g. Counter 0) that creates a pulse train (e.g. at 5kHz) from the timebase. Then you need to feed this counter output into the sample clock source of the buffered counter sample clock VI.
Let me know if you need help with the example code or you would like to know more about the issue.
Peter
Peter A.
Field Sales Engineer, NI Germany
