Counter/Timer
dividing source signal with 2 counters
I have a C/T 6602.
I want to divide by n(>=2) one external signal with my two counters at the same time. But the problem is that I cannot make the two Counter outputs  in-phase whenever I set the counters up. Whenever the order is made, the two output phases are random. I think that there is way to do what I want.
Thanks, GraceSun
(3,255 Views)
Hello GraceSun,
Have you tried any example programs?  You have not said what programming language you are using, but if you are using LabVIEW 7.x you can go to help >> find examples >> hardware input and output >> DAQmx >> Generating Digital Pulses and find a VI called Gen Dig Pulse Train (either continuous or finite).  You can simply put in for your counter channel "Dev1/ctr0:1" to have multiple counters in the task.  Your outputs will then be synchronized.
Laura
(3,242 Views)
