Counter/Timer
encoder losing count
I have a 1000 line count incremental quadrature encoder on a DC motor and it seem to be losing count when measuring angle with PXI 6259 M- series DAQ, LabVIEW 8.5 on a RealTime target system (running at 5000 Hz loop rate)
I'm using a US digital differntial to single ended converter to connect it to BNC 2120 (PFI 8/9 for channel A and B, 5V for power and ground).
Any advise for troubleshooting? Also where in the code should I incorporate the gear reduction ratio ?
Searched in the forum but did have much luck. (Please see attached vi for angular measurement).
Thanks for the help.
(5,480 Views)
Accepted by topic author V_Jain
Hi V_Jain,
A good place to start is to use a shipping example located at Help >> Find Examples.  Once this opens, make sure you select the Browse tab in the top left then double click Hardware Input and Output >> DAQmx >> Counter Measurements >> Position >> Measure Angular Position.vi.  These examples are proven examples which are usually a good place to start any program.  This code will give you a good idea whether or not your hardware is working properly.  Also, the gear ratio can be incorporated after the read (change your data by some multiple).
Jim Schwartz
(5,457 Views)
Jim,
Thanks for the help. Your suggestion was very useful to isolate the hardware issue.
(5,446 Views)
