Counter/Timer
error 10013 when using GPCTR_Control with ND_RESET
I am using two 6602 cards and a MIO E6035 in an PXI system. I program the counter and the MIO for bufferd operation and start the measurement. This works good.
Then I stop the actual measurement with DAQ_Clear for the MIO and GPCTR_Control with ND_RESET for each used counter on the 6602.
After a while I want so start a new measurement and do the same init again. The second time I often (not allways !!) get an error code 10013 (-10013 badErrorCodeError: The driver returned an unrecognized or unlisted error code) when I call ND_RESET.
Whe I get it once, I get it allways. WShen I stop my program and restart it, then the programming of the counters works aggain.
What can I do? Is there a command, so that I can init the
counter card completly?
I am using NI Daq 6.9.1.
Stephan
(4,242 Views)
Stephan;
This error occur when the GPCTR_Control try to access the wrong DMA table for some counter. If you are using more than 3 counters at each counter board, make sure to have the extra counters to use IRQs to perform its operations. Otherwise you might make the GPCTR_Control to access the wrong table for one of the counters.
Hope this helps.
Filipe
(4,241 Views)
I have the similar problem with 3 6602 board and 1 6220.
Do you know how to reset the boards ? My application does acquier continusly without restarting.
Thank's
(4,099 Views)
