Counter/Timer
error -89120 Source terminal to be routed could not be found on the device
Dear All,
I am generating a pulse train using a 6602 card on Ctr0. I use Ctr1 to read the number of counts from the 80MHz source gated by this Ctr0.
I get an error when starting the Counting process on Ctr1 when calling the DAQmxStartTask function: error -89120 Source terminal to be routed could not be found on the device.
I start Ctr0 without any problem, by using the StartPulseGeneration (see below), but I get into trouble for the second stage, when reading counter1.
Here is my code. Thank you in advance for your help.
Private Sub StartPulseGeneration ()
    ' Create the DAQmx task.
    DAQmxErrChk DAQmxCreateTask("", taskHandle)
    'Create Counter Channel for pulse generation
    DAQmxCreateCOPulseChanFreq(taskHandle, “Dev1/ctr0”, "coChannel", DAQmx_Val_FrequencyUnits2_Hz, DAQmx_Val_Level1_Low, 0#, 200, (dutyCycle / 100))
    'Specify continuous timing
    DAQmxCfgImplicitTiming(taskHandle, DAQmx_Val_AcquisitionType_ContSamps, 100)
    'Start generating the pulse train
    DAQmxStartTask (taskHandle)
End Sub
Private Sub StartCounting()
    DAQmxCreateTask("", taskHandleTS)
    DAQmxCreateCICountEdgesChan(taskHandleTS, "Dev1/ctr1", "mychan", _ DAQmx_Val_Edge1_Rising, 0, DAQmx_Val_CountDirection1_CountUp)
    DAQmxCfgSampClkTiming(taskHandleTS, "/Dev1/Ctr0InternalOutput", 1, DAQmx_Val_Rising, _DAQmx_Val_AcquisitionType_ContSamps, 10000)
    DAQmxSetCICountEdgesTerm(taskHandleTS, "Dev1/ctr1", "/Dev1/80MHz Timebase")
    DAQmxStartTask(taskHandleTS)
End Sub
(5,715 Views)
Hi Atacama,
I noticed you have posted the same question on this thread: http://forums.ni.com/ni/board/message?board.id=40&message.id=4210
For simplicity I will put all posts on the other thread.
Regards
Jon B
NI UK & Ireland
(5,704 Views)
