Counter/Timer
event-counting on DAQ6024E board using comedi drivers
Hi, I have a DAQ6024E card. Due to some reasons, i have to use rtai for data acquisition and hence need the comedi driver (ni_mio_cs) and comedilib functions.
However, i have not found any commands in comedilib to access the GPTC for event counting of an encorder input even though the ni_mio_cs driver has support for this. I wonder if anyone has solved similar problem?
(3,611 Views)
Greetings,
You may want to consider posting this question to the Driver Development Kit (DDK) discussion forum (link available below). This forum is an outstanding resource for questions regarding register-level programming (RLP), alternative operating systems, etc.
Driver Development Kit (DDK) Discussion Forum
Good luck with your application.
Spencer S.
(3,610 Views)
Actually, i got what i needed from comedi people.
(3,577 Views)
