Counter/Timer
filter pxi-6602 LabVIEW DAQ-mx
I have a PXI-6602 card.
The signal to measure is on the gate pin.
On the source pin, it is the internal 20MHz.
The counter uses the ND_BUFFERED_EVENT_CNT mode.
I have a LabWindows code with NI driver DAQ for this card which uses filter with this function <<< Line_Change_Attribute( device number, line name, ND_LINE_FILTER, ND_5_MICROSECONDS) >>>
I must rewrite the code to LabVIEW with NI driver DAQ-mx.
I use the counter to count edge mode.
I don't know how to configure the same filter in LabVIEW with DAQ-mx.
Can you help me ?
thanks
best regards
(5,135 Views)
Assuming you're using the external signal as a "sample clock" in your edge count task, you would enable the filter like this (called before starting the task):
There are other ways to configure what is essentially the same thing though--if you're using the external signal as something other than a sample clock (e.g. a "pause trigger") then there would be a different property that you would need to set instead.
Best Regards,
John Passiak
(5,127 Views)
Hello Richard,
This might also help you:
http://digital.ni.com/public.nsf/allkb/862567530005F09F8625698D00105F44?OpenDocument
Let me know if it answers to your question.
Jovan N. - Application Engineering
(5,090 Views)
