Counter/Timer
finite puls train in loop with Hardware timed single point RT
i looking for a method for generat a finite puls train in a loop which aquire analog input with hardware time single point. I'm using labview rt on a PXI 6251.
Thanks!
(5,369 Views)
Hello Raisch,
thank you for posting at the National Instruments Board. Please clarify, what you are planning to do:
Do you like to generate a finit pulse train or do you want to acquire data from the analog in?
For generating a finit pulse train, you need both (!) counter-units from your NI PXI-6251: one which generates the pulses, the other one, who counts the number of periods and stops the generation.
You find a simple example in the LabVIEW Example Finder (Help » Example Finder). Please navigate inside the Example Finder to:
Hardware Input and Output » DAQmx » Generating Digital Pulses » Gen Dig Pulse Train-Finite.vi
If you like to acquire analog data from your analog inputs using an external clock, please take a look to this example:
Hardware Input and Output » DAQmx » Analog Measurements » Voltage » Cont Acq&Graph Voltag-Ext Clk.vi
I hope, that these examples helped you to clarify the generation and acquisition of data using LabVIEW with DAQmx.
Best regards
Message Edited by MarianMO on 08-17-2009 02:32 PM
Marian Vorderer
(5,356 Views)
Hello marian,
thanks for your answer. I will explain my problem better:
I will in one loop an a RT Systems aquire analog data (with hardware time single point) then compute with a PID controller a number of pulse for the counter/timer output for a step motor. I can't use hardware time single point for the timing output. Examples who can chance Frequency and/or duty circle
i have found, but not a good method for chance the number of pulses in the loop.
Thanks for your help.
(5,352 Views)
Hello Raisch,
generate a number of pulses can be done with the example "Gen Dig Pulse Train-Finite.vi" I mentioned above. These pulses will be generated using the onboard hardware-clock of your NI PXI-6251.
What cycle time of the PID-Loop do you want to achieve?
Best regards from Munich
Marian Vorderer
(5,349 Views)
Hello Marian,
my problem is that I must start the pulse-task then wait generation is finished and final stop the task. (see picture) At this method a have problems with the communication with the RT target (for example: close connetion). The cycle time to aquire is 10Hz and to generate is 1000Hz.
I think, that is not the best way for using in one loop. You have a better idea?
One Question: can we wrote in german language?
Best Regards
Raisch
(5,327 Views)
