Counter/Timer
fpga NI 9223 Trigger
I'm using LabView FPGA with NI 9223. I have a signal that I would like to measure with a trigger so I may study and measure the signal. I am able to read the signal, but it isn't much use to me without the trigger. Has any found out how to implement an analog trigger with NI 9223 card or perhaps using it along with another card?
(6,077 Views)
Hello SMestril,
You can certaintly develop an application with the 9223 on a RIO platform that will respond to an analog threshold trigger and then respond as you see fit. A good white paper that outlines how this can be achieved can be found in the following link: http://zone.ni.com/devzone/cda/tut/p/id/3236.
Best,
Blayne Kettlewell
(6,070 Views)
