Counter/Timer
how to change default signal connection of counter
I am new to NI labview, in my application, i need to change  default signal connection of Ctr0. its output is PFI3, how to change to PFI4?
thanks a lot
BTW, how to post figures here?
(5,768 Views)
Hi hitbuyi,
You would need to set the following channel property (before starting your task) to choose the output terminal:
If you're using one of the other APIs (e.g. .NET or C) they have similar properties which you may set.
By "figures" do you mean images?  If so, you can do it by pressing the Insert/edit image button at the top of the reply window:
Reply to Message - NI Discussion Forums - Google Chrome_2012-10-02_14-20-59.png
Best Regards,
John Passiak
(5,737 Views)
