Counter/Timer
how to measure the rpm using NI 9411 and counters
How to calculate the rpm of a shaft using NI 9411 and counters?
(7,519 Views)
http://forums.ni.com/t5/Signal-Conditioning/measuring-rpm-using-DAQ-device/m-p/2571131#M7353
Additionally, if you set it to read a degree instead of pulse, your calculation will change a bit, but I'll leave that to you.
(7,501 Views)
Alternatively you can use the counter frequency input with DAQmx to measure the frequency and then just convert that to RPM.
(7,262 Views)
