Counter/Timer
how to reroute counter signal
Hi, I am using Labview 2010 and 6212 usb board. I am generating a signal using counter 0 which by default outputs signal to PFI12. However I would like to output the signal to PFI2 or PFI3 for instance instead of PFI12. The sample vi that I am using to generate signal is attached. Any help would be appreciated. Thank you, vk
(5,909 Views)
Accepted by topic author v-k
Found the answer.  Basically I needed to use CO.Pulse.Term property node as shown in link below.
http://forums.ni.com/t5/Counter-Timer/Counter-Output-with-NI-cDAQ-9188/m-p/2218208#M10898
(5,892 Views)
