Counter/Timer
is there an ISA equivalent to the PCI 6602?
I need at least a 4 channel counter card with simmilar software drivers for older CNC controllers.
(3,688 Views)
JPC ZE,
Unfortunately, there is no equivalent to any of the 660x family as an ISA bus. The E Series boards always have two counters with 24-bit resolution,and there are some of them that have ISA bus. That might be a work around.
Hope this information is helpful.
L Aguila
(3,688 Views)
Can you recommend a specific part number that I can use with the 24-bit counters? Thanks in advance.
Joe
(3,688 Views)
Joe,
There are several options, among which you can find the at-mio-16xe-50, the at-mio-16de-10, at-ai-16xe-10, at-mio-16xe-10, at-mio-64e-3, and at-mio-16e-1. If you only wanted for counters, I would look at seriously the at-mio-16xe-50.
L Aguila
(3,688 Views)
