Counter/Timer
labview as a tachometer
How to use a labview program as a tachometer to measure the RPM of a dc motor?
Message 1 of 11
(10,204 Views)
One way to do this would be to setup your counters to preform a frequency measurement. You should be able to find a shipping example that accomplishes this. If you know the freqeuency and duty cycle of the sqaure wave from your motor, you can calculate speed.
Anuj d.
Message 2 of 11
(10,196 Views)
My power drill DC motor is part of a setup in an experiment. As the voltage increases the RPM of the drill is NOT linear but changes in an UNCERTAIN way. Thus the voltage applied to the drill is not an indication of the RPM. To find the RPM, I need an external tachometer.
Message 3 of 11
(10,187 Views)
I have attached a file about my setup. I need to measure the RPM of the rotating disk with a tachometer. However I cannot afford one. I have build my own SIMPLE tachometer using a torchlight and a photoresistor diode. Can it work? How do I connect the photoresistor to my 6025E DAQ card? Which PINS? I have attached also the PIN sheet.Do you know where I can get a tachometer.vi.?
Message 4 of 11
(10,164 Views)
Hi everyone!
Do anyone know where I can get a simple tachometer.vi?
Message 5 of 11
(10,134 Views)
Check out some of the counter frequency measurement shipping examples in LabVIEW under:
Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Counter Measurements >> Frequency.
-Sal
Message 6 of 11
(10,126 Views)
Can my idea work with any of the examples?
Message 7 of 11
(10,083 Views)
Is your example found pn LV6.0
Message 8 of 11
(10,082 Views)
I am not able to locate any shipping examples that measures frequency. It could be I am using LV6.0. Please sent me an example in LV6.0.
Message 9 of 11
(10,081 Views)
Try a little harder. Why don't you simply go to the search tab and enter frequency? From the browse tab, you have Hardware Input and Output>DAQ>Counters. From there, you'll need to know the type of counter on your daq board. Check your manual.
Message 10 of 11
(9,759 Views)
