Counter/Timer
looking for quick ideas to synchronously start multiple counters on PXI-6608 at zero in a countdown from (T = -15 to T = +10)
I need to synchronously start multiple counters on the pxi-6608 within a countdown in labview. I will press a start button to initiate countdown. The 6608 will be synched with irig-b. I have gps reciever and I am able to get irig-b into labview for display. I also want to capture the irig-b time when countdown reaches zero and starts the counters. The countdown will continue 10 seconds after zero.
(3,362 Views)
You did not specify what you are synchronously starting multiple counters to do; however, most counter applications can be programmed to start upon receiving a hardware trigger. In order to hardware trigger multiple counters at a given GPS time we can use an example that has been written called "GPS Alarm Clock.llb." This example will generate a pulse at a user-specified time. In your case the user-specified time is 10 seconds from the current time. You will have to slightly modify this example such that the user-specified time is not entered on the front panel, but instead, calculated in software as the current time plus 10 seconds.
Synchronizing and Correlating Measurements to a Global Timebase with GPS
http://zone.ni.com/devzone/conceptd.nsf/webmain
/2FAD3B4E67BA766186256B9C00679F75?opendocument
If you look at the end of the document and expand "How to Program the PXI-6608 with GPS in LabVIEW" then you will see the example I am referring to. Furthermore, if you expand "Generate Trigger at User-Specified Time" you will see an explanation of how this VI works.
Justin Britten
(3,362 Views)
