Counter/Timer
making a counter for ttl pulses
Could someone help me in creating a pulse counter in Dasylab? I am using a TTL pulse to open and close a valve via a digital output, but I am having a brain freeze as to what modules I need to put together to get a display of the number of times the valve has been opened/closed. Even better, I would like to have a countdown of pulses such that the counter will know how many pulses the ttl is going to send, then count to zero.
Any help is much appreciated!!
(3,258 Views)
Hello ehall,
Are you using an NI DAQ or Counter/Timer board?  If so, please tell us which one.  If not, your question would be better addressed in the DASYLab forum.
Thanks!
(3,243 Views)
