Counter/Timer
measure PWM input to NI using labwindows
i want to measure PWM came out of controller. i use labwindows to develop this task.
but when iam searching example of DQAMX inside counter examples i had found that i can measure pulse width OR i can measure period
iam asking now i need to detect PWM (pulse width and period ) and i couldn't create the two handels on the same task......
So please tell me what i can do to measure the twice at the same time
thanks in advance
(6,236 Views)
Characterizing the frequency and duty of a PWM signal will require 2 separate tasks. A task for pulse width measurement and frequency/period will need to be created. Each of the 2 tasks will require separate hardware counters to do this measurement; you will have to wire the PWM signal into both sets of counters for the 2 measurements to occur simultaneously.
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(6,221 Views)
you mean that i have in my NI two counters CTR0 and CTR1 and i will apply the signal on both pins and start to detect task by task then handel the both tasks to return the width and period ........but in this case i will not be able to make pwm output from bench and input at the same time as i have two counter only ...IS IT right ??
if yes .....that is the only way to implement the pwm measure  but what semiperiod function means ???? i C it can detect the both levels periods but it will draw them not get them as values....???
thanks alot for your help
and waiting your reply
(6,217 Views)
Since you only have 2 counters, you can only perform 2 counter tasks at a time. If the PWM signal is not quickly changing, you can measure the pulse width, close the task, and then use the same counter to measure the frequency. I am unsure of your measurement requirements, but this is a possibility.
Eric
Eric Liauw
(6,211 Views)
Hello
thanks alot for your help .....
(6,199 Views)
