Hello!
I tried the "PulseWidth-Buff-SampClk-Cont.c"-Example. I got the following error:
DAQmx Error: Invalid timing type for this channel.
Property: DAQmx_SampTimingType
You Have Requested: DAQmx_Val_SampClk
You Can Select: DAQmx_Val_Implicit, DAQmx_Val_OnDemand
Task Name: _unnamedTask<0>
Status Code: -200300Here is the Example-Code:
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
int error=0;
TaskHandle taskHandle=0;
int32 read;
float64 data[1000];
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateCIPulseWidthChan(taskHandle,"Dev1/ctr0","",0.000000100,0.838860750,DAQmx_Val_Seconds,DAQmx_Val_Rising,""));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/Dev1/PFI0",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
//DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/dev1/PFI13",1.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
//DAQmxErrChk (DAQmxCfgImplicitTiming(taskHandle,DAQmx_Val_ContSamps,1000));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
printf("Continuously reading. Press Ctrl+C to interrupt\n");
while( 1 ) {
// DAQmx Read Code
DAQmxErrChk (DAQmxReadCounterF64(taskHandle,1000,20.0,data,1000,&read,0));
printf("Acquired %d samples\n",read);
fflush(stdout);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
What could i do?
Andreas
