Counter/Timer
measuring tdc position in an ic engine
sir,
I have to plot pressure vs volume using labview. i had sucssefuly added my pressure transduzer.
i have 360ppr encoder pls tell how to interface this encoder in labview and then for every 360 pulse it should reset.
my problem is in tdc position (top dead center) counter should be zero when ever it reaches the tdc.
pls give segestion.do you have example program means please attach it.
Message 1 of 1
(5,640 Views)
