Counter/Timer
multiple waveforms with different start triggers
I have four waveforms, AO0, AO1, AO2, AO3 - I want to have each waveform start with a different start trigger, PFI3, PFI4, PFI5, PFI6 respectively.  When I attempt it, it says the clock resource is already in use.  How do I share the clock for the different waveforms?
Can this be done on the NI-6722?
Bill
(6,526 Views)
the clock can be the same across all waveforms.   I do not see how to share the clock across the waveforms.
(6,525 Views)
so the problem seems to be that I need a different task for each AO to handle the start trigger and each task needs to have a clock defined.  So, I need to share/reference the clock.  How can this be done?
(6,516 Views)
is it possible to apply a different start trigger to each waveform in a specific task?  Under some pressure here.  Thanks for your help!
(6,503 Views)
I have a 6722 card - which is supposed to have two timers.  I need at least access to the second timer and I do not see how to do that.  Anybody have any idea how to do that with the .net C#?  Any help is greatly appreciated.  thanks
(6,487 Views)
i am assuming each timer can be used as a sample clock with the 6722
(6,485 Views)
Unfortunately the card doesn't work that way.  You can't trigger the AO lines individually--if you are using hardware timing/triggering the AO lines need to be in the same task and would shave the same sample clock and start trigger.
Best Regards,
John Passiak
(6,470 Views)
