When using PCI 4451/4452, we can use the GPCTR0_UP_DOWN Signal and input this signal on the DIO6 pin; this general-purpose counter 0 counts down when the pin is at a logic low and counts up when it is at a logic high.
If we are now using cRIO 9421, how do we achieve both the count up and count down capability which can be easily done using DAQmx?
Thanks thanks!
-Mr Bing
