Counter/Timer
pci 6601
Looking for example c code to genrate a single pulse from an external rising edge trigger with the 6610.
Want to be able to control the pulse width, no delay.
Thanks.
(6,686 Views)
Accepted by topic author dougdoug
Hi Doug^2,
There are lots of great examples installed on your computer with your NI software.  If you go to your Windows Start Menu > All programs > National Instruments > NI-DAQ > Text-Based Code Support > ANSI-C Examples.  From here it sounds like you want to go to Counter > Digital Pulse and find your appropriate example.
Best of luck!
Ryan C.
(6,672 Views)
Perfect.
Thank you!
(6,669 Views)
On further inspection, the example does not use an external trigger.
Suggestions?
(6,664 Views)
Doug^2,
Based on what you're trying to accomplish, it's tough to give you the exact code you need, but I did fine this example which may get you started. https://forums.ni.com/t5/Example-Code/Archived-NI-DAQmx-Continuous-Analog-Input-with-Both-Start-and/...
Also, there are a lot of other examples in that directories I navigated you to before that may be helpful.  Check the Analog Input directory.
Best,
Ryan C.
(6,654 Views)
