Counter/Timer
pci 6602: configuring a frequency-divider with daqmx using labview7.1
i´m using labview 7.1 and the pci6602 counter-board. i want to configure a counter as an frequency-divider with varaibale division-rate, witch is a easy thing to do with the classic "old" daq-driver.
it´s recommended to use the "new" daqmx-driver, and i want to do so, cause i´m using also other ni-devices and want to use the same driver for all of them, but i can´t find any possibility in the daqmx-vi´s to configure such a frequency-divider.
i also couldn´t find any example-code for this problem.
please help me!!
(3,758 Views)
I've found an example, i hope it will help you!
Regards
Christian Mergl
(3,741 Views)
hi, thanks for the answer, but unfortunatly it´s not what i ment.
i need to configure a counter on the pci6602 wich divides down the frequency "f_in" of the square pulses connected to it´s "source" pin by "divisor" and puts out square pulses with frequency f_out=f_in/divisor at another pin. That process should take place only on the 6602-board without using the cpu.
i´ve found the solution already, how to configure a counter on the pci6602 with daqmx like described above. see attachment.
servus
markus
(3,739 Views)
